Old 08-18-2011, 01:43 PM   #22 (permalink)
Daox
I just got in from testing the SGe's graph timing adjustment. As I said, the time duration each bar represents on the graph can be changed. Its not as easy as setting it to a sepecific time duration unfortunately. The setting is simply setting a number 1-8. 5 is the default and makes each bar represent about 9 seconds (1.5 minutes for the whole graph since there are 10 bars). When set to 1, each bar represents about 100 seconds (~16.5 minutes for the whole graph). When it is set to 8, each bar represents around 2 seconds of history (~20 seconds for the whole graph). So, there is a pretty wide amount of adjustment in there. I wouldn't mind seeing the band shifted toward longer amounts of time, but I guess I'm used to the Prius' 5 minute bars too.
