Old 08-18-2011, 06:22 PM   #190 (permalink)
aerohead
inclines
Originally Posted by dkruitz View Post
Very interesting Phil! My brother-in-law used to have an NT650 fun bike.
Not sure if I missed it in the thread, but are you allowing for if the truck/trailer takes an incline and the trailer is no longer inline with the truck?
dkruitz,I'm usually surprised by 'reality' whenever I put something new on the beast and take it for a run.
I have tried to out-guess the environment.The top panel will now be fixed to the truck and articulate vertically to clear the lazy-c frame which supports the side panels.During torsional deflection the c-frame will lift the top panel away for clearance.
The side panels are on the trailer and move with it and cannot bind against the trailer itself and during torsion,if they 'kiss' the upper panel,it will simply lift to clear and then return to 'level'.
The bellypan details are not completely ironed out yet.I have a plan although that could lead to a surprise.
On an approach to a ramp,there is enough room for the trailer to cock without striking the integrator.
In a dip,the c-frame will 'dive' into the void behind the integrator.
If things work out,the trailer and panels will allow for the full range of motion without any interference,with everything moving around on rollers.
So far so good!
