Old 08-20-2011, 12:27 AM   #113 (permalink)
Bicycle Bob
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
[QUOTE=euromodder;256790]I doubt they'd have rear wheel steering, which is fine for low speed forklifting but a bear to handle at high speed - these vehicles can hit 60mph / 100kph.
Rear wheel steering works fine for the Dymaxion car, and many others since. The key is to use the same geometry as a regular car running in reverse, but to add a steering damper. That way, it wants to go straight. The only real disadvantage is the extra time and road width needed for maneuvers. You have to swing the back end to steer the front.
