Old 05-14-2008, 09:33 AM   #31 (permalink)
EngineeredCivic
Be aware guys that when you use a narrower tire (175/70/14 vs a 185/70/14) you are also changing the diameter which will throw off your odometer which will effect your MPG calculation. Make sure if you go narrow you compsnate with a taller profile to keep the same diameter.
1996 Civic DX - 140,000 miles and still sipping gas
