Old 08-21-2011, 10:31 AM   #334 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by neilzero View Post
Tango Charlie says "never downshift" I rarely try down shifting as my attempts are jerky and thus hard on the clutch and other parts. Do vehicles use more fuel down shifting than idling in neutral?
Downshifting is used to help engine braking, appears to use less fuel as the fuel flow is cut off.
Yet it's essentially a braking technique, and braking wastes fuel unless you're powered by gravity and need to check your speed.
Coasting in idle beats engine braking.
