Old 08-21-2011, 06:39 PM   #14 (permalink)
rtuhro@lighthouse.net
do air tabs work, is that a valid question
if you want to run a business i don't see that is a good question. it doesn't matter if they work what matters is do people think they work. if you really must convince your self they work, i would suggest they likely do something good. if not better fuel econemy better stability. i haven't researched the air tabs patent position but i suspect it would be impossible to have a really sound position on technology that is 100 years old, so you might want to consider vacuum forming your own design that accomplished the same end.
