Old 08-22-2011, 10:05 AM   #5 (permalink)
oil pan 4
Originally Posted by Nerys View Post
SO is there anything we can do to SIMULATE this?
suggestions? thoughts? ideas? info?
Maybe a warm air intake with mild water injection.
Only problem with water injection is its not proven to boost FE on N/A gas engines at least with stock cold air type intakes.
For FE on a gas engine during compression you want your air/fuel mix to get as hot as possible with out preignition and with out having to pull timing before being lit off by the spark plug.
