Well that *is* very encouraging!
I have upped the tire pressure to 40psi now and am striving to keep the revs under 2k. It is hot here now and I just had the windows tinted, so running the AC for a few days more than I normally would.
So preheated air is better in the winter? I always thought cooler was better...more dense.
I also need to yank the defrost detect switch harness loose as I think this affected my winter numbers last year, from 2010 on you can't just override the defrost AC with the AC switch...bummer.
