Tach, Wideband 02 Sensor, Oil pressure.
Those are the most vital Gauges i beleive for any sort of vehicle (if you dont have a tach then i would say vac/boost gauge). The wideband with ACCURATLEY display your Air to Fuel ratios so you can keep track of what everything is doing @ the moment.
Oil pressure is the gauge that will make sure your engine is running properly. God knows that it has saved me a couple times when i had an oil line blow off of my turbocharger. Otherwise i would have no idea.
www.BOOSTandDESTROY.com
Yes i sell performance parts..... But hey~ they make your engine more effcient so technically im selling "Green" parts.
2002 Chevy Blazer 4.3L / Auto.
"THE QUEST FOR 35mpg"
