Old 08-23-2011, 11:04 AM   #1 (permalink)
skyl4rk
Coasting Down the Peak
skyl4rk's Avatar
Toyauto Pickup - '94 Toyota Pickup 2WD
90 day: 36.32 mpg (US)
Versa Base - '09 Versa Sedan 1.6 Base
90 day: 41.69 mpg (US)
Using LED trailer lights, wiring question
I have some truck trailer LED lights, which have a ground wire, a running light wire (normal light), and a right/left turn wire (bright light).
I tapped off of the wires in the back of my car. My car has a separate bulb for brake lights, the turn signals have their own separate bulb. At first I was going to connect both the brake light wire to both right/left turn wires, and the right and left turn wires to the appropriate sides.
My concern is that the brake wire connection to both of the turn signal wires will mean that both lights light up when one turn signal is lit.
Is there any way around this other than putting in additional lights for the brakes?
Did I tap the wires incorrectly?
Nissan Versa Aeromods
