Clutch Spline Outer Diameter
Hey Ben, do you know your clutch spline outer diameter? I was thinking of getting a half of a lovejoy that has the same inner diameter as the motor shaft, and the other half of a lovejoy that has the same inner diameter as the outer diameter of the clutch spline. Then I could just ask a shop to weld that piece without having to get any lathing done. Hopefully, the outer diameters of the 2 lovejoy halves would still be the same.
