The spreadsheet should be viewable to anyone with the link as it is. As for the fuel pump, it is a cam driven direct injection pump capable of pushing 2000 PSI; past that, and the injectors fail to open. Unfortunately, I can really only run up to about 1950 PSI max (after upgrading the pump to its maximum level) due to issues with the relief valve.
Even then, past a certain point I will probably still need new injectors AND a new fuel pump (neither of which exist) to go further.
As a side note, I already run 1750-1775 PSI on the stock pump/injectors.
Edit:
Here's the link again just in case:
https://spreadsheets.google.com/spre...thkey=CLqLjoYL
