Old 08-24-2011, 02:14 PM   #51 (permalink)
cfg83
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
thriftee -
Originally Posted by thriftee View Post
Sorry for digging up the old thread, and thanks for posting it in the first place...
No problem, it's a complement.
So, if you had to do it over, would you:
1. Leave it alone
2. Use the 5th from a 97- SOHC so the stretch from 4th to 5th wasn't so big
3. do it with the 5th from a 98+ SOHC as done
4. use a 97- SOHC complete trans
5. use a 98+ SOHC complete trans
I'm thinking of doing this if I get an DOHC SC2, which it seems might be a better car and motor overall than the SOHC SC2 model, but would like the economy of the SOHC or better on the highway
I would do #3 over again. Second to that I would consider #5, but I would need to crunch the numbers first at a gear/tire ratio calculator like this one :
Fatboy Raceworks » Graphical Transmission Gear Ratio Calculator
The quote you are referring to was in response to jasonm changing his *final* gear ratio. That's like changing the size of your tires because the final gear ratio is in play in all shift positions, just like the tires.
CarloSW2
American Solar Energy Society
