Old 08-24-2011, 07:42 PM   #5 (permalink)
DonR
The Wife's Hot Rod - '09 Pontiac G8 GT
Last 3: 23.22 mpg (US)
Big Outback - '13 Subaru Outback 2.5i
Little Outback - '02 Subaru Impreza Outback Sport
To track this I say you need some instrumentation. Something that will show ignition timing while you are on the road. Set a base line and try to test different octane gas under the base line conditions.
The 09 G8 has the base engine I want to use in my next build. A 12:1 compression LS3 stroked to 6.7L. I am trying to learn as much as I can about its DOD, VVT systems before I start the build.
I will use VVT, have a couple different plans on how to control it.
Not sure about DoD yet. I would like to use it but not sure how.
The LS3 doesn't have the DoD. The L76 does. Basically it is an LS3 with a different cam that won't break the DoD lifters.
