Thread: 1,180 Mile Tank
Old 08-25-2011, 01:33 PM   #31 (permalink)
Diesel_Dave
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
My max sidewall is 80 psi. If I remember correctly the recommended pressures are 55 psi for the front, 45 psi for the rears. If I ever carry a heavy load, I'd probably decrease my pressures a little, but most of the time I run unloaded or only lightly loaded. It's been about 3 months (3,500 mi) since I bumped up my pressures from 60 to 70. So far I haven't noticed any unusual tread wear. I probably should take another close look to make sure.
80 psi max sidewall seemed like a lot to me when I first looked at it as well, but I guess I just have "stronger" tires. My wife has 17-inch tires on her Blazer and her max sidewall is only 35 psi. I guess it just depends on the tire.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
