Thread: 1,180 Mile Tank
Old 08-25-2011, 01:38 PM   #32 (permalink)
Diesel_Dave
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
Originally Posted by Rick323 View Post
Are you putting the heaters on the oil pan? or are you going to put them on the transmission or differential? I'm pretty sure the block heater on my ford is 1150 watts-that's good enough for the engine (oil, antifreeze...everything). I plan on putting a couple of heaters on my car and trucks, the trannys are definitely getting one.
Right now I have two heaters. I plan on putting both of those on the oil pan. Later, I may put one on the tranny and another one on the differential.
I'm a little confused about what you said about your block heater being good enough for everything. If it's a coolant heater it heats the coolant. If it's an oil heater it heats the oil, etc. A coolant heater won't heat the oil no matter how big it is. Granted, if your coolant heater heats up the coolant and block, your oil will heat up faster once you start the engine, but it hasn't heated the oil or tranny at all (directly).
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
