Old 08-25-2011, 06:30 PM   #2 (permalink)
aerohead
looks fast
Originally Posted by Mcbroiler View Post
I finally got around to posting some pics on the aerodynamic truck bed camper top I've been working on. I'm Using 1/8" 1+1/2"x1+1/2" aluminum angle for the framing. The frame will be annealed, shaped, and welded to get the proper alignment for the sides and top. Not exactly sure yet what I will use for the sheeting, but It will be fully functional with lift dampers and locks. This is just the rough draft so any and all honest criticism is appreciated.
For a shortbed,the angle looks too fast and I'm afraid you'd have separation with no chance of re-attachment.
It's better to have less slope but good flow,then you can doo even more mods later with success.
Check out the Aerodynamic Streamlining Template Part-C at Search EcoModder above.
