Motorcycle tires cost alot more, good touring tires will give you the best mileage but could cost you $150 each or more, insurance can be really cheap or it can cost 3 times more then your car insurance, it all depends on the size of bike you get so check before you buy a bike, if you can get a fuel injected motorcycle then buy it! otherwise you will have it in the shop getting the carb rebuilt every year or two, helmets are a must, but they need to be replaced every 6 to 10 years as the plastic ages, padding wears out and they become less effective.
