Originally Posted by Greg Fordyce
Since the controllers would be connected in parallel, voltage is going to be the same. You would need to make sure both controllers get an identical throttle signal and then each controllers output will be matched. That is both controllers will be working to provide the same amp output and so should stay in balance. When all the bugs are worked out of the 1000 amp controller then you have an easy upgrade path to 2000 amps.
You might want to check out Adam Brunette's EV Corvette Conversion:
http://ecomodder.com/forum/117833-post28.html and
http://ecomodder.com/forum/119036-post31.html.
The ReVolt system is modular. You only need one (1) controller, for single or multiple driver PCBs and Power PCBs.
-Mark
![Big Grin](/forum/images/smilies/biggrin.gif)
