Old 08-26-2011, 11:30 AM   #3 (permalink)
kach22i
Originally Posted by BamZipPow View Post
The first one is the closest...ideally the bottom of the template should be at the bottom of the wheels...
Thanks, I thought that was the closest.
Always line up with the "high point" of roof?
The first mark with the zero degrees, that is the center of the roof, or does it have to cut through the driver's head?
If your whole roof conforms to the template, then where is the center? Doesn't it shift back a couple of feet on my example?
