Quick shot I took the other night of the wheel cover after I did a bit of sanding and spread a second layer of resin on:
[IMG]
[/IMG]
After using some Rustoleum filler primer:
[IMG]
[/IMG]
Today I mounted them to the car and did some wet sanding:
[IMG]
[/IMG]
Wanted to smooth out some of the high spots and reduce the "suede look" to give them a more finished appearance. I needed to get the garage cleaned up and reorganized for other projects, so I'm just going to run them on the car like this for the week; next weekend I will remove them and give them another shot of primer. They look pretty good in grey, so I'm debating over whether to spray them in a clearcoat after I'm done priming, shoot them grey, or maybe use a dull silver on them.
