Lets try this again
So a while back i finished building the controller and when I put it in it didn't work. So i shelved the project for a while. Today i hooked the controller up to a 12volt power supply (for the board) , a small compressor motor (12v) and a deep cycle battery also a 12 volt.
everything powered up ok and when i pulled the lever (on the pot) the motor spun!
so on a small test scale the controller seems to work fine.
put it in the car with the 120volt pack and nothing...not a sausage!
what could be the problem?
