Old 08-28-2011, 01:28 PM   #65 (permalink)
Patrick
Patrick's Avatar
Hot Tamale - '10 Toyota Prius III
Based on this idea, fins would not work on a rear or mid-engine car, right?
No, they would still work. The idea is to get the center of pressure behind the center of gravity. If the CG is further back you may need larger fins, more fins, or the fins may need to be positioned further back to get the same effect. Or you can reposition some other items to move the CG forward.
The Following User Says Thank You to Patrick For This Useful Post:
aerohead (04-14-2012)
