Old 08-28-2011, 02:21 PM   #5 (permalink)
skyl4rk
Coasting Down the Peak
skyl4rk's Avatar
Toyauto Pickup - '94 Toyota Pickup 2WD
90 day: 36.32 mpg (US)
Versa Base - '09 Versa Sedan 1.6 Base
90 day: 41.69 mpg (US)
I bought a "Taillight Converter - LED Compatible", NAPA part number 755-2161
Cost was about $30.
This did the job and was easy, just tap into the tail, left, right and brake wires, attach a ground, and you have an output trailer connector with ground - tail - bright left - bright right wires.
The part that I got was packaged with a NAPA label, but it appears to be the same as this part:
Taillight Converter Universal Kit (independent bulb turn signals) :: Hopkins Towing Solutions
Nissan Versa Aeromods
