Old 08-28-2011, 06:04 PM   #1 (permalink)
320touring
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
BMW 318iS e36 Project- Aiming for 45MPG (imp)-Suggestions Wanted!
318iS Ecomodding project
So after 9000 miles in 6 months, Ive decided that I really should try this ecomodding malarky on the daily driver..
The car is a 1994 BMW 318iS. its a 1800cc 16v 4cyl engine with circa 140bhp.
5 speed manual box (1:1 5th gear) and a 3.45 rear diff
Weight is 1240kg (2750lbs)
Car is completely standard and has returned approx 40.4 MPG(imp) over my time of ownership.
Currently I'm using the following hypermiling tips/tricks:
Tyres at 40PSI
P&G (engine on) using indicated load of 20mpg on the onboard econometer
DFCO using gears to reduce car speed approaching junctions etc
Both myself and my girlfriend use the car regularly- she's pretty good at the hypermiling, and is usually within an mpg or two of myself.
Aims
1. Improve the Car's average MPG from 40.4mpg to 45mpg.
2. Maintain the current level of practicality.
3. Utilise only "Reversible" Mods, so that car can be returned to stock if required.
4. Costs of any modifications must be covered by the savings gained
5. Total Outlay for Modifications should be no more than £250
6. The car must appear almost unchanged visually-Kammbacks etc are a no no with the police/insurance companies.
Here are some pics of the car, along with my proposals
(i'd be grateful if someone could place the "ideal" aero template onto the side view, please)
Side View (rear wing is missing due to me needing to refit it properly)
I've now refitted the wing- but I can see that having no rear wing would be advantageous- fitting a no wing bootlid should resolve this
Front End
Immediate thoughts centre around the Large Lower Grill/upper grill
closely followed by potential for wheel spats/smaller door mirrors
Rear End
Initial investigation suggests not too much to do outwardly here.. however I see potential for improvement by reducing the "parachute " effect of the bumper by sealing the gap from the spare wheel pan to the bumper
Front Wheel Arch/ Alloy wheel shape
These "Bottletop" alloys are an odd design, esentially the curved outer spokes are higher than the centre- meaning the alloy looks like a shallow bowl.
I could see covers working for these- any suggestions as to how to mount them?
Rear Arch
Again I can see potential for spats infront of the rear wheels, and if possible a way to tidy up the rear edge, as it sticks out past the wheel.
additionally, wheel covers could be fitted. I'm not prepared to fit rear arch covers though, as this car is fairly rare in having very solid rear arches- I want to keep it that way
Bonnet(Hood) to Windscreen angle
Any suggestions welcome here-is it worth trying to modify the angle?
Engine Bay Overview
Immediate things that spring to mind are
Top cover to quicken coolant heating
Wing/Slam panel seals to minimise air into the bay
Engine Bay Gap behind grills and Below Radiator
This has lots of potential for improvement:
bellypan to close off the bottom of the bay
Sealing behind headlights
Slam Panel Cover
Internal Grill blocks
Current Air Intake setup
Again, scope for improvement here by fitting a Warm Air Intake ducting air from the exhaust manifold (right rear corner of the bay) to the Air meter.
There's plenty of space infront of the engine to run some tubing- I just hope the air meter can adapt to the lower density warmer air
Other Ideas
Engine bay Weight Saving
Electric Fan Install
Interior Weight Saving
Source Smaller Wing Mirrors
Fit Taller Ratio Diff (3.25/3.15?)
Full length Belly Pan
I'd be interested to hear your suggestions/ideas/observations- please dive right in!
Thanks
My Blog on cars- Fu'Gutty Cars
http://fuguttycars.wordpress.com/
US MPG for my Renault Clio 182
