Old 08-28-2011, 07:13 PM   #8 (permalink)
Ryland
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
Yep, Dave Cloud's has two motors so each motor is moving less weight forward then the geo metro would weigh if you pulled the engine, fenders and bumpers off and tried to power it with a single motor, he also has a solid state speed controller for each motor and I am going to bet that his spacer for that sprocket is a solid spacer, not long bolts that thread in to the tops of drilled out lug nuts.
Like I already said, the design as posted in this thread would be kind of like revving your engine up to 3,000rpm and dropping the clutch, if that is how you drive all the time then you are going to end up braking a lot of parts and if you are trying to move an entire car with a single drive wheel with a pulley that is dangling off the tips of some bolts so it clears the tire then when you apply that power someone is going to get hurt and people doing stupid stuff that gets them hurt or killed is why we have so many laws.
