Originally Posted by redyaris
When you find a straight sided fairing that that does not "generate" side force please let me know. That way I could make that the front of the motorcycle and have no aerodynamic drag force at all.
It is the curve that generates the lift ,that being a differential pressure on either side The bike you have built would generate far less side lift than my original drawing .My idea would have a lower overall drag but the forces from side winds would be far higher.The entry areas you use and which will have to use I think reduce the lift from the curved sides .
I'd love to know why Allert works so well!
