Originally Posted by Gasoline Fumes
I was actually going a bit faster than usual for this tank. It seems like 2000 RPM and 50 MPH is about ideal for this Honda. I've tried slower cruising speeds and never saw anything this high. My previous best of 54 MPG was also around 50 MPH. I'm not sure if the engine is more efficient at that speed, or if it's just longer coast times and more momentum to take me up hills.
If you can repeat it you have your answer. Longer coast time and momentum up hills can be a big help.
Do you have any type of instantaneous mpg instrumentation? Big help imo, can help you find out were you get the best mpg with out having to run full tanks. Keep up the good work.
