Old 08-29-2011, 11:24 PM   #13 (permalink)
skyking
skyking's Avatar
90 day: 23.82 mpg (US)
90 day: 15.1 mpg (US)
90 day: 49.05 mpg (US)
Mule - '07 Dodge Ram 3500 ST
On my first trailer I ripped Schedule-40 PVC pipe in half with a circular saw and used the inside surface as a mold to make wet layups of radius sections.
Triple waxed,and Polyvinyl Alcohol,and the parts came out with little prep work required before prime and topcoat.
A children's green ABS outdoor play slide might be about the right size for you.Sometimes you see them at yard sales and flea markets.
Thanks Phil. I will use pipe for mine, only it will be an outside mold if I go that direction. This will be finished 'bright' like my truck if all goes well.
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
