Thread: Vvt
Old 08-30-2011, 04:04 AM   #12 (permalink)
Piwoslaw
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Originally Posted by Ryland View Post
It sounds like if it's just the VVT-i then it's just the intake side.
Before VVT in Toyota's, Toyota had a set up where some of their 4 cylinder engines had 8 intake runners, one for each of the 8 intake valves, one of the intake runners on each cylinder had a butter fly valve, so that even tho the valves were all opening only one of them at lower speeds was getting fuel/air so it was more like having two intakes on the car, one for low rpm's and one for high rpm's.
Originally Posted by Arragonis View Post
What I'm wondering though is what affect the inlet VVT system has on whether the engine is running its best at WOT vs part throttle.
I've read about something similar in GM's European engines, for example the newer 1.0 12V (Z10XE) has a so-called TwinPort version (Z10XEP) which actually has two intake paths, one much longer than the other. At idle and low load one of the intake valves remains shut and all of the air goes through the longer intake route, which is supposed to cause more turbulence and better mixing, resulting in lower fuel consumption and cleaner emissions. At higher loads the second valve opens, allowing more air in through the shorter route.
In VVT-i opening only one intake valve at low load causes the air to enter the cylinde at a higher speed, increasing turbulence.
