Originally Posted by Piwoslaw
One of the things she can't get used to in our diesel is that it just keeps going in 2nd or even 3rd when she takes her foot off the gas. It freaks her out.
Because it coasts better ?
Going off the gas with a diesel should give some healthy (if somewhat inefficient) engine braking.
Another is all the attention Svietlana tends to get, which doesn't make the situation around us any safer
The mods are reversible, you could consider removing them while your wife uses the car more.
On the experimental front :
- I couldn't repeat the 85 kph (53 mph) @ 43.5 km/L (102 mpg)
- 30 while idling (about 800 rpm) in 4th works
though it's seriously lugging the engine when going up the slightest incline ; level or even slightly downhill it copes surprisingly well
