Old 08-31-2011, 09:19 AM   #2 (permalink)
winker
Here is my modified code (pin 10 was setup to output the digitaly processed signal (i.e. the square wave)
It use the injector settle parameter to determine if it is seeing a start pulse (I have mine currently set to 80uS, which as you can see works quite well).
Code:
#define dspInjectorPin 10
boolean lookForOpenPulse = true;
void processInjOpen(void){
  //20110831 AJT Peak and Hold ;)
  if(lookForOpenPulse){
    injHiStart = microSeconds();
    digitalWrite(dspInjectorPin,HIGH);
void processInjClosed(void){
  long t =  microSeconds();
  long x =  elapsedMicroseconds(injHiStart, t);
  if(x<parms[injectorSettleTimeIdx]){
    lookForOpenPulse=false;
  else {
    //    if(!lookForOpenPulse){
    tmpTrip.injHius += x;
    tmpTrip.injPulses++;
    if (tmpInstInjStart != nil) {
      tmpInstInjTot += x;
      tmpInstInjCount++;
    else {
      tmpInstInjStart = t;
    tmpInstInjEnd = t;
    lookForOpenPulse=true;
    digitalWrite(dspInjectorPin,LOW);
pinMode(dspInjectorPin,OUTPUT);
The following is a trace showing the injector input at the top, and the digitally processed signal (pin10) out. Looks good!
https://picasaweb.google.com/lh/phot...eat=directlink
and zoomed in (note small spike is injector opening and large spike is injector closing).
and the following shows a close up at idle of my injector signal
Last edited by winker; 09-01-2011 at 05:39 PM.. Reason: Found bug in code, so before any comments added sorted it.
The Following User Says Thank You to winker For This Useful Post:
California98Civic (09-08-2011)
