Originally Posted by MetroMPG
Did you happen to note your average speed for the tank? Context is good. Not minimizing your achievement.
My best 104 mpg fill-up in the Firefly was at ~20 mph average, per the SG (which is not a "rolling average" speed - it includes time stopped, up to 5 minutes).
It's my usual ~25 mph average, by the scangauge. That means 30-35 rolling average. Same as I've been doing on this commute for years. I've got 35, 45 and 50 mph speed limits, which are ideal for good mileage. I do a 25-40 P&G cycle most of the time, adjusting a little higher or lower at certain points. (like 5 mph past the neighbors as I approach home.
Actually, this time the Scangauge reported 100+ mph average toward the end. I think there's an overflow error somewhere in the hour counter when you run a tank out past 7 weeks.
