Originally Posted by hondaguy72
That's a hydraulic type clutch setup. If you have the conversion for that done, the Y8 will work, but the ratios are way too short for good fe with that motor. You really want the cx or vx transmission to go with it.
yeah i already have the clutch master-cylinder and stuff put in from a hydro vx. but the problem is i don't have the y8 bolts for the transmission case? can i use the vx bolts for those, can everything just bolt right up without any problems? can i use the d15z1 vss? or i have to buy a y8 sensor will it bolt up to the vx harness connector?
what gas mileage will i get with the y8 tranny. and how close is the gear ratios. i just need a asap for it.what is fe? i need to get it running. but im waiting on the clutch.
