Old 09-05-2011, 05:47 AM   #34 (permalink)
oil pan 4
All the guys that clam there engine is most efficient around 2000RPMs, live by that code and believe its the best engine speed for there truck to run at are the ones that will never see over 20mpg.
After I install the intercooled turbo set up with water injection I may swap to 2.73 rear end gears. Could end up just shy of 35mpg with just using mostly 1980s and 1990s technology.
One problem I see is you could get the engine chugging along at a low enough RPM to where the alternator does not produce enough power to run the electrical system.
Another would be if you had an auto transmission, the pump pressure out put could be so low that you are sliping your torque converter lock up when chuging along. I can adjust the pressure on my TH700R4 so it wont be a problem for me and the 6.2L came with just about the lowest stall converter ever produced.
