Old 09-05-2011, 12:57 PM   #78 (permalink)
Vekke
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
Originally Posted by Arturasz View Post
Hi, I wan't to buy new engine oil for Lupo 3L. Now I am using 0W30, but as i see my supplier has 0W20. Stay away from it, or go away? ;]
There is no oils with proper vw standard (vw 506.01 or higher) with 0W20 so I would not put it in my engine. If you can find a oil with proper vw spec please let me know. If it fulfills the standard then it should be ok. I will propably put next time Agip 7007 0W-30 which is cheapest or new 0W-30 from agip which is called i-sint tech. Newer oil should be better so might try that new version.
Red Line Synthetic Oil - Gear Oil for Manual Transmissions - MTL 70W80 GL-4 Gear Oil
For gearbox I will try redline MTL which is 70W80, but still fulfills API GL-4. VW recommends 75W90. If you have balls to test the best option would be redline shockproof light.Red Line Synthetic Oil - Gear Oil for Manual Transmissions - Lightweight ShockProof®
Gearbox oil change interval is 30000km if I have proper data.
Rest of lupo mods will be revealed at x-treme motor show at the end of september. Target bar is set to 1st price trophy in some category!.
X-Treme.fi
Mods that I will try to finish to the show:
- Controllable air dam
- New tires + wicked rim wheelcovers
- wicked "decals" all over the car
- Little bit of painting
- window tinting
etc.
I will update the fuel log all the time but no pictures will not come before the show .
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
