Originally Posted by JRMichler
Frank is right, it ain't ethanol. When they went to 10% ethanol around here, I did not see a mileage change. I'm sure that I would have seen a 3% change. My truck is, and has been, running 10% ethanol.
I suggested it because I see a drop in my mileage if I use E10 as do my parents, the two people I work for also avoid it in their work trucks because they have said they have seen mileage drops as much at 20%, one of them has a very stable route and uses his truck very lightly, so I think it's worth checking to see if you can find premium that doesn't have ethanol and see if it helps, if it doesn't help you are out and extra $.10 a gallon? I know you said you were on a tight budget, but think about it anyway.
