Old 09-06-2011, 08:57 PM   #39 (permalink)
oil pan 4
The battery in my truck was getting drained at idle.
Even city driving was draining them, I would charge them up, drive around shut the truck off and they would be a 12.4v.
I have caused a few electrical problems by switching to an electric coolant pump, electric fans and electric fuel pumps on the truck. I also plan to add a gast compressor (I tested it and it draws 50 amps at no load) and a 2,500w power inverter.
The alternator that the 6.2L came with was sized for an all mechanicaly controlled and driven diesel engine.
There is a rebuilt 95 amp ACdelco unit ready to replace what ever is in there now and I picked up some free solar panels that should barely cover "off" power draw and hopefully be some what good for battery float charging.
