Originally Posted by brandonppr
I gave it a try. At first I thought my DIC was not logging the miles because it would say 0mpg with engine off key on, but when I restarted it my avg mpg jumped up. I only drove down to the store a few miles from my house so I haven't had time to try it out, but I did increase my DIC avg MPG by 1 MPG in a short trip.
The first thing you should do is
read the owners manual and see what it says about towing or coasting etc. Back in the good old days the manufacturers would recomend that if your vehical had to be towed more than a specified distance you should remove the drive shaft or use dollies. As a general observation I dought that coasting for a mile or two would harm the transmision. But read the owners manual first and don't get sucked in by two bit opinions that may only be wearth a nickle.
