I started out with a vacuum gauge but found it to be a bit misleading. When I began using the Scangauge 2 I learned the what has benefited my MPG the most, drive in the highest gear possible at all times (with the exception of acceleration). You should be able to get past 30 mpg average if you keep at it. I have, and my engine is .4 liters larger!
-Miles
Best 15-mile commute city/highway mix: 37.7 mpg
Best tank so far: 31 mpg
