Old 09-07-2011, 12:43 PM   #3 (permalink)
oil pan 4
The BSHC charts are made at full load. Normally cruising speed is in that island from the factory.
I think combo #4 would be the way to go.
After doing this 5 gear would only be for cruising. It would be nearly useless for going up hills or passing.
I plan to do something like that for my car. Where I run really tall gearing when I swap the engine and transmission. I will build a high compression 6.7L LSx serries engine bolted to a 6 speed with a top gear of 1:0.5 and use the original 3.08 diff gears for testing. At 70 mph it should be turning about 1400RPM.
I plan on swapping the rear diff and will chose gearing based on my tests with the 3.08. I figure I will keep the 3.08 or go to 3.23
