Old 09-07-2011, 02:20 PM   #23 (permalink)
JRMichler
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 43.95 mpg (US)
Yeah, I would also expect a small truck to get similar mileage to the Mercedes. Here's a few things that will kill mileage 30 or 40%:
1) Ignition timing retarded about 10 degrees. I don't know how this could happen with a computer controlled engine.
2) Fuel mixture always on full power enrichment. I don't know how this could happen with a computer controlled engine - maybe a WOT throttle switch failure?
3) A really bad burned exhaust valve. A compression test will diagnose this.
4) A seriously dragging brake. You would feel the heat radiating just standing near it.
5) (Maybe) Camshaft out of time - worn chain (does your truck have a timing chain or a timing belt?) or belt/chain jumped a tooth or two.
6) (Maybe) Worn lobe or two on the camshaft. This happened to me years ago. I know it will reduce power, I don't know if it kills gas mileage.
7) Something I haven't thought of.
The Following User Says Thank You to JRMichler For This Useful Post:
JatMat (09-07-2011)
