Originally Posted by popimp
You're being sarcastic about the killer commute thing right? The 20W oil is fine. The recommended oil is 5W-20 but I use 0W-20. MetroMPG please do the import from you know where.
Killer as in a bad way for FE but good as far as the environment and such. I guess I miss understood. I thought that you used the van to do shopping and thought that the distances traveled would be short, less than 5 miles. Which is a FE killer on a cold start. My apologies.
