Originally Posted by ElectricZX2
Could be I'm only getting 600 amps because the Good Lord knows I would smoke my homemade coupler with 1000 amps  . At any rate...instead of going up to 511 or whatever the reference is it goes up to like 270 or something like that. The math worked out that the reference was the same percentage of 1008 of what I'm getting...
It sounds like your controller is not mapped properly for the throttle range. T-max-rc should the same as the raw throttle reading when pushed all the way to the floor and t-min-rc should be the same as raw throttle when you foot is off the pedal.
Anyway to get the software off of a controller?
It is only possible to get an image of the firmware off the controller. You wont be able to get the actual code back.
-Adam
