Old 09-08-2011, 05:18 PM   #211 (permalink)
Piwoslaw
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Thanks for the info Euro
I checked that all of those oils are more expensive than the Total 5w30 I'm using (~27€ for 4 liters vs 20€ for 5 liters). But I'll keep hunting.
While driving today I noticed the following:
  • After the coolant temperature settled around 79°C the idle consumption was 0.62-0.65 LPH. Other than the DRLs I also had radio, position lights, and windshield wipers on lowest setting.
  • I stopped and killed the engine after ~6-8km (phone call). The engine started quite easily.
  • Idle consumption dropped to 0.52-0.56 after 14km.
  • After that, starting the engine after killing it takes 4-6 turnovers before it catches
  • Turning the position lights off raised idle consumption from 0.55 to 0.62 Turning the position lights on adds 6x5W=30 watts, plus dashboard lighting. At the same time, the on-board computer's backlight dims. It's hard for me to believe that the OBC's dimming backlight saves more than 40-50W. Very weird.
As for the idle consumption being some 0.1 LPH higher for the first umpteen kilometers, this may always be the case, but previously went unnoticed. I know I've seen 0.52 LPH many times, but I can't be sure this was at the beginning of a trip. Maybe the ECU waits after the coolant warms up for the block to soak up some heat before going into lowest fuel consumption?
