Originally Posted by DieselFan
Hi Slowmover,
Sounds like you're reading the site today so I'll chance another question!
This one related to our thermostats.
I am running the Dodge dealer thermostat and my temperature is very stable but always below half mark on the dash guage so I just installed a Scanguage II and sure enough, reading is consistent at 182-184 F.
I have read many say that we would gain mileage by running closer to 200 F and many posts seem to indicate that our OEM thermostats are 190 F so I changed the thermostat thinking it was operating lower than spec and installed a new dealer thermostat, I don't want a NAPA, bad reviews. Results are still giving me a low 182-184!
What are others runing the 5.9 L Cummins seeing?
Is there a Cummins part # for a 190 or even 195 F thermostat for our engines?
Thanks
You're probably running a 180 F thermostat. That starts to open at 180 F. My truck has the 190 F thermostat and usually runs ~200 F (+/- 5 F) when warmed up. Here are the Cummins P/N's:
180 F: 4990285
190 F: 4929644
200 F: 4929642
EDIT: P/N for 180 & 200 should be reversed (200 deg is 4990285)
