Old 05-15-2008, 12:21 PM   #7 (permalink)
blackjackel
Whitey - '05 toyota corolla LE
90 day: 28.91 mpg (US)
Send a message via AIM to blackjackel Send a message via MSN to blackjackel Send a message via Yahoo to blackjackel
Originally Posted by dcb View Post
The information might be on the obd bus, but that is a long way from getting a scangauge to display it, unless you are ron delong, or his latest version allows you to display any pid you want. Any open source obd scanner software could be adapted to display it (again, assuming it is available on your car)
$19F4 Gear box ratio
$19F5 Current gear
http://www.obdproject.com/OBD2Info/Specs/pidlist.htm
I guess i'm in luck cause I have the latest version (with xguage). If I'm right, you want me to program those pids into xguage:
http://www.scangauge.com/support/pdfs/SGMan5_0.pdf
I'm assuming that I should enter the PID into where it says TXD in the manual link above... am I right?
