Old 09-09-2011, 11:45 PM   #8 (permalink)
CrazyLee
The Beast - '93 Fleetwood Flair includes kitchen sink
90 day: 9.2 mpg (US)
The Bigger Beast - '03 Winnebago Sightseer Motor Home
Got pictures back.
Hi, I found out this morning the photo's weren't loaded onto the server. I fixed that tonight. Comparing the traces for other P&H injectors they don't look like mine turned out. I got 50 MPG in my converter test. I think I know why. The mpguino may be reading the trace upside down! Looking at the small pulse gap between the actual first and last pulse. If I invert the signal it may read OK.
Nah! I still wouldn't get the actual pulse width. But it explains the 50 mpg reading.
I'll keep trying. I got the pre-built 'guino and I can't rebuild the code.
I may the Inj Delay to 1350us to see what happens there. It's at 500us now. I'm reading 13 mpg right now and 10.5 mpg is what I have been getting.
I really need to do a mpg run. I just filled up the tank. UGH! 70.119 gallons @ $3.509/gal= $225.00 I drove 60 miles w/ my 57 chevy in tow. The gauge shows about 5-7 gallons gone. about 8.5 mpg ( 5/5ths on my gauge. ) about 15 gallons per mark. 787 miles at 10.5 mpg. Hows that for hyper-mileing!
Cheers, Lee
Thanks, Lee
Originally Posted by winker View Post
@CrazyLee: can't see your pics, infact on your page the only pics I can't see are the mpguino trace ones! Guess you may have moved or be in the process of updating them.
I tried the comparator route, but got nowhere fast, as the gap between the pulses became almost smaller than than the hold portion of the waveform. Thats when I went for the software solution.
I have set my detection pulse to 40uS (aka injector delay parameter), and this seems to work very well. I now need to house my unit, then calibrate it.
If you have access to a scope might be worth trying my software mod, and see what you get.
