Old 09-10-2011, 11:38 AM   #5 (permalink)
bestclimb
Smeghead
escort - '99 ford escort sport
90 day: 42.38 mpg (US)
scoobaru - '02 Subaru Forester s
90 day: 28.65 mpg (US)
It is still in balance. If the bar is not moving the moment is the same on each side. (Edit: or the difference in moment is not enough to overcome the friction in the system)
W___________________W
.................A.................
Now we slide the bar
W____________________W
..........................A.......
The bar will drop on the left and rise on the right. Slightly rotating on the fulcrum. until fulcrum is directly under the cg of the tilted bar or the bar falls over.
This can farther be demonstrated with a "stickier" fulcrum with a larger radius.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
