Old 09-10-2011, 03:18 PM   #7 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by Vekke View Post
I think water is best, but it rusts off your system so you have to stuff to make it suitable...
Water is certainly not the best, it boils too easily.
That's why coolant is added.
Best option is to get rid of the water altogether, and use a propylene-glycol based coolant (Like the Evans NPG coolants). With a higher thermostat, and higher fan on/off temps - I might give that a try on my diesel.
It would improve the oil dilution problems a bit from the other end - hotter cylinder walls, giving a bit less condensation.
